controling 20 bits
Do not Add and Subtract when it comes to Boolean logic.  AND and OR are what you want.  If the bit comes in as a TRUE, you OR your number with 1 where that bit belongs (1 OR 1 = 1).  If the bit comes in as a FALSE, you AND that bit as a 0.
So let's just say you have 0xFFFF right now.  You are told to endable bit 5.  So you perform 0xFFFF OR 0x0010 = 0xFFFF.  Yep, that test is still enabled.
Now you are told to disable bit 5.  So you perform 0xFFFF AND 0xFFEF = 0xFFEF.  Or if you had nothing enabled before, you have 0x0000 AND 0xFFEF = 0x0000.  Yep, still not running anything.
GCentral
Message 11 of 12
(365 Views)
thanks
Message 12 of 12
(331 Views)
