control reference of modified element present in array of cluster ?
Hi All,
I want to get the reference of the modified element in the array of cluster. I have an event case for that particular control, but it gives only the reference of array, not the element present in the array of cluster.
below is control hierachy
Array
- Cluster
    - Controls
    - Cluster
       -Controls        <------- I want to know the reference of this control if it is get modified by user.
Hope will someone help me to solve this issue.
(2,080 Views)
Accepted by topic author GRamy
Hi Ramy,
you will not get a reference to that special control. You may get references for the clusters and their contents in general…
To check which element has changed you need to compare "Old Value" with "New Value", both are given by the event case terminals!
(2,058 Views)
