First of all, we will need to know what hardware you are using. I hope you've got the NI Motion controller and an NI DAQ board. If so, you're looking good. Jonnie5 was talking about continuous buffered acquisition. There are several examples at your fingertips that ship with LabVIEW. Under the Help menu, go to Find Examples. On the dialog that appears, select Hardware Input and Output -> DAQ -> Analog Input -> General and then whichever "Cont Acq .... (buffered)" example you like.
Run that example in parallel with your stepper motor routines and you've got a prototype. If you do not feel that your LabVIEW skills are developed enough to integrate the two functions in parallel, there are LabVIEW experts waiting to help at a nearby Alliance Member co
mpany like ours.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
