control a m061-fd02 step motor with labview
i am trying to control a m061-fd02 step motor via cdaq 9178,and i dont really know how to begin,can some one help me
Message 1 of 8
(3,928 Views)
The cDAQ 9178 is an 8 slot chassis. What modules do you have in it?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(3,925 Views)
if you can tell me which modules i need i will go and buy them,
but when i will have what i need,what is the next step?can i connect the motor directly to the module?is there any labview code available which solve this problem?
thank you very much for your answer
Message 3 of 8
(3,917 Views)
First, tell me a bit about your application. What are you trying to do with the motor?
Mike?
LabVIEW Champion
Message 4 of 8
(3,912 Views)
Thank you both for posting on NI Discussion Forums. It looks like you are close to finding an answer to your questions. Also, our engineers at National Instruments would be glad to help you find the products that you need to meet your applications needs. We are here to help.
I believe that this post should have been made in the Motion Control board rather than the LabVIEW board. These forums are moderated by NI engineers. By posting in the correct board, the posts are routed to the correct engineering teams so that we can assist you all more efficiently.
Message 5 of 8
(3,881 Views)
I have two cameras and a mirror between them,with the engine I control the motion of the mirror,and the type of cammera i use.so now i am trying to sync the mirror motion with labview but i dont really know how
Message 6 of 8
(3,855 Views)
now i see that i got the 9215 module
can i connect the motor directly to it?
Message 7 of 8
(3,832 Views)
A NI-9215 has 4 simultaneously sampled analog inputs.
How do you expect that will help you control a motor?
You need to contact your local NI sales rep so they can visit you and discuss your application.
Message 8 of 8
(3,827 Views)
