07-29-2021 05:56 PM
I’ve been getting into the Queued Message Handler Design Pattern. At the same time, I’ve been trying to figure out where/how I can use the Master/Slave Design Pattern. While researching both of these, an NI article recommended taking a look at continuous measurement and logging project template as an example of both of these. So, I closed my program, opened the template, then my brain melted, and now I’m here….
Q: Is the continuous measurement and logging project template an example of good LabVIEW code? You don’t have to go in detail. I just want to make sure it is before I spend the considerable amount of time I’ll need to analyze it, and I don’t want to pick up bad habits by emulating it. (Don’t want to repeat the errors caused by using the serial port examples.)
- Is it really okay to have that many cases in a case structure? That looks like it would be hard to debug.
Thank you,
garthenar
Related Resources I’ve been using
https://labviewwiki.org/wiki/Design_pattern
https://www.ni.com/en-us/support/documentation/supplemental/06/rules-to-wire-by----part-i.html
https://www.ni.com/en-us/support/documentation/supplemental/06/rules-to-wire-by----part-ii.html
https://labviewwiki.org/wiki/Master/Slave
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1r9CAA&l=en-US
https://lavag.org/topic/15080-masterslave-vs-producerconsumer-templates/
https://www.youtube.com/watch?v=2k3ZDwJolbA&list=PLmF-6jvwRvVNFzBjzh4bQDjFbv6lShcth
https://zone.ni.com/reference/en-XX/help/371361R-01/lvhowto/caveatsrecmndtnsevnts/
07-29-2021 06:32 PM
Personally, I hate the continuous measurement and logging project template. I think it is overly confusing, and I still don't completely understand it.
May a suggest the JKI State Machine as a template or reference. It is similar to a QSM, except the queue is a string shift register that contains your commands. Multiple State Machines can be linked by User Events. It takes a little bit to get used to, but it has built tools that are useful. You can get it through VIPM.
mcduff
07-30-2021 01:25 AM - edited 07-30-2021 01:28 AM
Hey, i'm fairly new to Labview but i've been using the continuous measurement and logging project (see attached file) as the basis for my program.
I find it good, the structure is really well done as every action is well separated but programming this can be a bit confusing. The loops runs in parrallel but you need to be very aware of what goes on in every loop at the same time. I have a lot of cases in my message handling loop, maybe it's a problem but each case is precisely denominated and does a single and simple action. There's many, but they're tiny. Divide and rule as we say.
Just my newbie take on this
07-30-2021 12:23 PM
mcduff
Hey Mcduff,
I'll definitely add the JKI state machine to my list as another intermediate design pattern to learn, along with the others from the wiki (https://labviewwiki.org/wiki/Design_pattern). I'm trying to widen my experience with LabVIEW and add more tools to my toolbox so to speak. I have a big interest in being able to write decoupled, cohesive code. Would you say the JKI design pattern is good for.... Never mind, I think the picture from their site (below) answers the question I was going to ask.
Thanks again,
garthenar
