I have installed the fpga compile worker on a different pc in our network to remotely compile the vi's to a bitfile. My problem is that I can not connect from my development pc to the compilation pc. All ports are open between the two pc's, and I can transfer datafiles between both, but it is not possible to connect to the compilation server.
Here is what happens; When I open the compile worker on the development pc, I click configure and choose the "Connect to a compile server" radio button. In hostname I write the IP-adres of the other pc, and user name and password is the login of this other pc.If I click ok, I get the error "Authentication with server failed. Verify the worker is configured correctly and the user name and password are correct".
I have checked the "Allow users to connect remotely to this computer" in the Server Configuration.
I've tried several user name and password combinations but nothing worked. Can somebody tell me what I am overlooking here?
With regards,
Dries
