I have a problem in Scan From String node. The node takes the System language for parsing and converting to timestamp.
For Example, If the system Language is Dutch(Netherlands) we have to give "Do" instead of "Thu" for Thursday.
Is there any way to force LabView to use only English Language irrespective of the System Language.
I referred this link Language preference and found AppLanguage key to give the language. I added this Key to LabView.ini file with value "English". It was not working. I also tried other values like "english","en". These were also not working. Please also specify how we must give value for the above-mentioned key.
Please go through the VI to get a clear picture of the problem.
Viknesh
