compare time hour and minute
hi,
          how to compare 11:30 to 12:00 the two thing is string datatype....i use string to nember converter  but it will return only  11.
(5,676 Views)
11:30  = 11.30 (Replace : by .)  then convert in Numeric (use scan from string) and
12:00 = 11.00 (Replace : by .)  then convert in Numeric (use scan from string) and can comapre easily
compare minutes if hour value is same otherwise no need.
hope it helps..
-Amit
Amit
CLAD
(5,656 Views)
hi,
      the scan string also give two seperate number(11:30 mean 11 and 30).
(5,645 Views)
The Scan from String function will allow you to parse 11:30 into two integers, 11 and 30.  Use the Help for the function to see how it works.  Right-click on the function (once you lay it on your Block Diagram to gain access to the Edit Format String option (you'll want to use a format string something like %d:%d).  It is up to you to do the arithmetic on minutes and seconds properly (one way is to convert everything to seconds, then subtract).
(5,639 Views)
Accepted by GokulGKM
The easiest way to do this is to format the string in to a timestamp.  You can then simply subtract the stamps to tell the number of seconds in between your two timestamps.
(5,622 Views)
