compact rio connection lost
   I cannot connect to my compactrio, first it works fine but using NIMAX the card cnnot be found.
   is there any kind of thing i  can do ?
Sa
(2,732 Views)
Have you tried to "Ping" your compact rio?  This will check basic network connection. Also, what is the Controller(OS) and labview version? If it is a VXworks OS.and you fault the tcp/ip coms the only thing you can do is a re-boot to get tcp based coms to work again. UDP Coms and your code will still work.
(2,723 Views)
