comment lire les donnée d'une dll
bonjour
je suis entrain d'utiliser un vi qui possede une dll. je voudrai savoir comment configure le dll
coordialement skipi
(2,690 Views)
French to English for more responses:
hello
I'm using a vi which has a dll. I want to know how to configure the dll
skip coordialement
(2,679 Views)
Hai
Do you know the details of the function and the parameters to be passed for the functions? Do u have only one function named nomFonction (mentioned in your screenshot)? Please post in bit more about the dll.
Mathan
(2,678 Views)
OUI je connait tous les details du vi ( entrée et sortie). Le probleme que j ai c'est le paramettre il ne prend pas toute les entres du vi automatiquement.
Avez vous un exemple a me montrer.
MERCI
COORDIALEMENT SKIPI
(2,657 Views)
Accepted by topic author skipi
French to English
YES I know all the details of vi (entry and exit). The problem I have is the paramettre it does not take any entries vi automatically.
Have you an example to show me.
THANK YOU
Hai, CLN only loads all the functions inside your dll automatically. But for each function, you only have to declare the parameters and it won't get loaded automatically. If you find difficulties in declaring the parameters, post the specifications of dll along with the dll and also post your vi.
[Note: Please post here in English for more responses from the forum. Please use translate.google.com for translation if you don't know English.]
Thanks for your understanding,
Mathan
(2,644 Views)
hi
thank you for your responses. I finally managed to solve the problem. thank you for your help
(2,633 Views)
