12-18-2008 12:01 AM
I have different 1-D arrays which I want to store in excel. All arrays in a single MS excel file.
How do I do that?
12-18-2008 01:42 AM
Hi Shan21,
are your arrays from different type? If you need a "real" Excel file, then you have to use ActiveX functions. To write two different array (different type) use two invoke node (value) to write the different types.
If you only need a Spreadsheet file, then the easiest way is to convert both arrays to string and write all at ones.
Hope it helps.
Mike
12-18-2008 04:15 AM
If I convert it to a spreadsheet, can we manipulate the numbers inside the spreadsheet cause now they are strings?
12-18-2008 05:45 AM
Hi Shan21,
yes, you can change what you want in your file. Do you need to read the values later?
Mike
12-18-2008 05:56 AM
12-18-2008 05:59 AM
Hi Shan21,
it shouldn't be a problem. Do you have different types? Can you show an image of what you make?
Mike
