comandline, open *.lvm files from windows explorer
hello,
my program (mess.exe) saves the measurement results in some *.lvm files (measure1.lvm, measure2.lvm, ...)
When you make a doubleclick on such a lvm file in the Windows Explorer, my labview program "mess.exe" should be start and load the data from the klicked lvm file and display the data.
I solved this with the comandline function and with the first lvm file this works fine.
But when my program "mess.exe" ist already runing, Windows changed to my program but I don´t get any information about the second doubleclicked lvm file. The comandline shows always the path of the first file.
Can somebody help my ?
jan91
(3,255 Views)
This seems to be a variation of the question the poster asked here.
Not sure where somebody is supposed to respond.
(3,245 Views)
smercurio, it's on the same topic but a different issue. Thus the poster can mark each solution seperatly 😉
To the question: maybe there is some event you can catch. I don't have something the like on 7.1, so I don't know. Otherwise you might need to find a way to talk to the OS (register for the event on your own). Browse msdn on this...
Felix
(3,240 Views)
