> How about...
> If you open your text files into strings, then 'match pattern' within
a
> while loop or otherwise search the strings to replace any 'newline'
> characters with Tabs. If you then convert the string to an array, you
should
> have one long row. You can then transpose this to one long column with
one
> of the array tools - 'reshape array' maybe - I can't remember. If you
do
> this for all 4 files, then use 'build array' to stick them together,
you
> should get what you want.
> Paul
Paul,
Thanks for your help. I used the match pattern to find and replace
the new line characters with tabs. The four columns have 10 data
points, then two zero's separating them from the next 10 points. I used
the same idea to get rid of the retur
n characters and replace them with
tabs, which got rid of one row of zeros. I've tried the same idea using
backspace, form feed, space characters, etc, and I still have one row of
zeros separating my data points. Do you have any idea what this
character could be? I tried all of the characters in the manuals and
none will get rid of this problem. Again, thank you very much for your
push in the right direction!
Heather
Sent via Deja.com http://www.deja.com/
Before you buy.
