06-28-2007 11:08 AM
06-28-2007 11:24 AM - edited 06-28-2007 11:24 AM
Doyon,
Depending on what is acceptable you could use a Text & Picture ring to assign each item a color -- this would not appear on the text itself, however. You could also make your ring come out to a case structure that contained a property node and correct properties for each case (i.e. case Yellow sets the background property yellow, etc.). See the example I added to yours.
Message Edited by NI David on 06-28-2007 11:27 AM
06-28-2007 11:26 AM
06-28-2007 11:34 AM
I have the version 8.0 can you save your Vi for my version.
06-28-2007 11:55 AM
06-28-2007 12:09 PM
06-29-2007 03:24 AM
