05-17-2011 09:29 AM
Hi, in a FPGA VI I have connected directly the output of a FPGA I/O node to the input of another module, as in the attached figure.
The input shows a red coercion dot.
I have three questions:
1) why this coercion dot?
1) how can I eliminate this coercion dot?
2) would this limit the resolution or the speed?
regards
Max
05-17-2011 09:44 AM
Forgot to add that I am using Labview 8.6, Ni-RIO 3.6 as software
and CRIO 9012 with FPGA NI 9111, and NI 9263 and NI 9205 modules
regards
Max
05-17-2011 09:20 PM - edited 05-17-2011 09:21 PM
The AI is fxp 26.5, the AO is 20.5. thus the coersion dot. does not affect performance in this case.
The 26.5 covers the potential range of the module across all of the module ranges. this will vary by AI module. the 20.5 covers the range of the AO.
05-18-2011 05:18 AM
Dear Stu,
thank you very much for your reply.
Where is it possible to have access to this kind of information?
How could I check the property of the fxp of the AI and AO?
Moreover when I click on the wire connecting the AO to the AI, it gives me fxp26.5, whereas according to your
information it should be the dimension of the AO: 20.5.
Best regards
Max
05-18-2011 07:25 AM
you answered half your own question already. you determined that the wire coming out of the AI is fxp 26.5 the wire is always determined from the source, in this case the AI. that is how I determined what type is was. as for the AO, I did a "create constant" operation on the input to the AO to see what type it created in order to determin it's type.
I do not know if there is a comprehensive table that describes all these types anywhere but I just do what I described whenever I have that question.
