cluster to xy graph
I received a lot of help getting my vi to the point it is at but I need a little more.
I am wanting to display two signals (one is digital, one is analog DCV) on a xy chart along with a time stamp.  The analog DCV is around 6VDC.  With the attached vi, I can see the timestamp and capture every DI change just like I want to but I never see my analog signal.  I have verifed it is indeed ~6VDC.  I'm sure I am missing something.  Any help would be appreciated.  Thanks.
(2,352 Views)
You're building an array of digital data in a shift register but only ever entering a single sample for your analog data.
If you build an array of your analog samples like you are for digital it should work the way you want it to.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(2,341 Views)
