cluster to easy text report?
How can I display data of type cluster in an easy text report?
Pls. see example attached.
(2,552 Views)
The Easy Text Report.vi requires a string as input. Use Format into String or other numeric to string functions to create the string you want. You probably do not need the array or cluster.
Lynn
(2,544 Views)
