cluster of control references: want to access the control value
I want to be able to save and set control values that are saved (XML). I have my controls on about 5 sub vi's. So I thought it'd be a good idea
to put all the control references in a cluster from the several sub vi's and save and read from one point.
I can get the cluster values (i.e. the references to the controls), but how to proceed from here? If somebody has a better idea it is very welcome.
I have also read Ben's nugget here, but it deals with references to controls in a cluster, not references to a reference of a control in a cluster 🙂
(4,414 Views)
You want to set the controls to a certain value obtained from the XML...?. Is that right or You want to do something else....? One thing I want to get cleared you are having Cluster of Reference or Reference to the Cluster of Reference....?
(4,409 Views)
Actually I am putting the control references now directly into a functional global, which leaves me with an array of references. I think with this I can now acces control
properties from the control over all sub vi's and save data to file.
For example, I want the user to be able to switch language and hence change control captions.
(4,404 Views)
Yes you can do so by the unbundle function and access each property of each control...
(4,396 Views)
Thank you for reading that Nugget!
I use a GUI Controller in many apps so I can grab refs in sub-VI's.
Here are some screen shots of them in use.
The first "GUI Cnt" is a wrapper around the AE and invokes the action "Set Analysis mode" then another call let me get a cluster of the refs so I can choose based on the name.
This image shows what that action does.
THis is what happens when going into collection mode.
That is a small set of what you will find in my image gallery Feel free to browse (yes I know there is a lot of Olivia in there Smiley Wink ) and ask if anything catches your interest.
Ben
(4,383 Views)
I like your error combiners Ben, very neat Smiley Happy
very much off topic, but:
I noticed you unbundled each item with a sepertate Unbundle - for neatness. Is there any expense to that, as opposed to unbunding in one Unbudle?
Richard
(4,366 Views)
One of those sub-VIs is called "Error Fork Stacker" and is Open source and posted by Mike Porter in this thread. I will leave it as an exercise to the reader to create the other version Smiley Tongue.
The sepearte unbundles are not any less expensinve than a single unbundle node. I also use sepearte unbundles for "documentation" purposes since it puts a nice offical lable right next the the node.
Ben
(4,359 Views)
