click radio button to configure settings
    I'm measuring some amplifier parameters using VISA functions over a frequency range.These are 2 types.1)UPA and
2)VPA.These two differ by frequency range.First, I have to select one of the two.For this I've used a radio button.After
selecting one of the two, I've to configure the settings(This I want to do in a seperate window).Once I configure the
settings,if I click Ok button then it should proceed to the next step i.e., measuring parameters(Power, harmonics etc...)
using VISA functions.I've written the code for measuring parameters using VISA functions.Now, my question is
   1) If I select a radio button the program should go into one mode(either VPA or UPA)
   2) After entering VPA or UPA it should configure the settings (frequency step size(Hz)).
   3) After configuring the settings, If I click Ok Button it should come out of that popup window and should start     measuring parameters.
                         How can I go about it?
RobinHood
(2,124 Views)
Please keep it all in one place. Thanks!
(2,113 Views)
Sorry Alten,
                     Can you help me solve this problem.
RobinHood
(2,108 Views)
