04-17-2008 03:00 AM
04-17-2008 04:12 AM
04-17-2008 04:41 AM
Hye!
Thanks for replying!
Well, i'l building using the NI cDAQ 9172. That module that ive chosen is also compatible to NI cDAQ. actually i need a module whiwh has analog Input and output. It should support a variation from 0 to 24V. Can we choose a module which allows us to choose between continuous, triangle ans square signal? certain modules like NI 9481 has a characteristic of logic-form A. What is that suppose to mean?
thanks again!
Dhirah
04-17-2008
07:49 AM
- last edited on
03-24-2025
06:58 PM
by
Content Cleaner
Hi!
NI 9481 is a RELAY output, it is not an ANALOG output module! You need an analog ouput module to generate arbitrary functions, that vary from 0V to 24 V continuously.
please clearify your task! Do you need digital outputs or you really need to generate functions? Usually 24 V is used in industrial automation plants as digital...
Anyway, for Analog out modules, look among these, in particular define sampling rate (rate at which samples are generated), DAC resolution (number of bits), etc...
graziano
04-17-2008 07:52 AM
04-17-2008 08:49 AM
04-17-2008 09:14 AM - edited 04-17-2008 09:15 AM
