If you are working on cRIO, it is possible that you are on the FPGA target. FPGA does not support floating points. The default numeric representation is integer. You can switch to fixed point if needed.
If you are working on the RT, you can use floating point. But from your description it sounds like you have integer nevertheless....
hope this helps,
Norbert
Norbert
Expert: Geometry
