change subVI without stopping main VI
Hello, is there any possibility to change the source code of an active but apparently not used subVI without stopping the superordinate VI. I would like to do that to fix an error in a subVI without stopping the main application.
Thanks in advance.
(2,741 Views)
You can't edit a VI that's running or "waiting to run". Once you pressed the run button, the VI is compiled and you can't change it. You should be able to edit a VI that's called dynamically, using VI server methods.
___________________
Try to take over the world!
(2,740 Views)
In this thread is a discussion about doing this but I have not tried it to see if it works.
Joe.
"NOTHING IS EVER EASY"
(2,728 Views)
