I use cfp-2010 module to communicate the cfp-ai-100 and computer by ethernet and hub. However, I have a problem about the connection stability. When I try the sample vi as FP-AI-100.vi, I can read the data from cfp. Unfortunely, it does not work well everytime. Sometimes, it works well, then if I run the same vi again later without any modification, I would get the message about "Unable to connect to the data item on the module. The FieldPoint Server is unable to connect the the FieldPoint network module. Possible cause is that there is a broken connection or the network module is not powered on. : FP Read.vi". It looks like the communication between computer and cfp-2010 is not stable. Can anyone help me to solve this issue? Th
anks.
Fred
