case selector small .b
Highlighted
I don't know if this something important that I should know, but what is that small .b in front of a case selector? NI had no mention of it in their documentation. I tried entering it in front, but it would not accept without turning red.
(322 Views)
Highlighted
Accepted by topic author jimlandowski
Hi jim,
it really helps to show an image, and it helps even more to attach real code...
So I can only guess: did you enable the radix display in the case structure?
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
(316 Views)
Highlighted
If you have a numeric selector, you can show the radix. Yours is set to binary, I guess.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
(307 Views)
Highlighted
Thanks. That was it.
(266 Views)
Highlighted
You probably would have also noticed that you can only enter numbers consisting of only zeroes and ones. 😉
(257 Views)
