capteur magnétique+arduino+labview
bonjour  svp les amis m'aider je ne peux pas faire une séquence labview d'une femrture de porte ... lorsque la porte est fermé il maffichier un message dans labview "fermé la porter"
(514 Views)
Hi chedise,
@chedise19 wrote:
hello please friends help me i can't make a labview sequence of a door closing... when the door is closed it displays a message in labview "closed the door"
What is the problem?
Why can't you create such a LabVIEW VI?
I guess all you need is a boolean control and a case structure. Inside the "closed door" case you display your message using a OneButtonDialog function…
(506 Views)
comment je peux faire ca ?
(494 Views)
Hi chedise,
@chedise19 wrote:
how can i do that?
By using the functions mentioned in my previous message!
When you want to learn LabVIEW I can recommend the TrainingResources offered at the top of the LabVIEW board…
(490 Views)
