09-26-2014 09:30 AM
@Sahiti2013 wrote:
To avoid more confuison,Here is the scenario,
The version that was on the driver attached is from the driver manufacturer.
I do not have any version of labview INSTALLED on my system. I am using the driver in Test Stand 2012 using a labview adapter.
I make sure I match the VI version and the run time engine version on TestStand 2012 to load the VI.
But for this specific driver, I was not successful in loading the VI at all.
As I understood that only 8.0 OR LATER are supported on TS 2012, I have asked to upconvert the driver to work with 8.2.1 Labview runtime engine.
I have now got a.LLB file of the driver mass compiled in Labview 2012 from discussion boards( and also attached here). I have tried the mass compiled LLB file on TS2012 but still have issues loading the VI as it moans about different version of SUB VIs.
However I am still trying to fix this version incomaptibilies. Any help would be much appreciated
You may get better advice posting what you wrote in the TestStand forum http://forums.ni.com/t5/NI-TestStand/bd-p/330
09-26-2014 09:37 AM
