can't see Targets and Devices
I've installed LabView 2016 to learn about FPGAs as I'm a beginner in this field. As in the tutorials for creating a new project, I should right-click the project root and select New»Targets and Devices. Why does the ''Targets and Devices'' option not appear? Do I need any other configurations or software to start learning about FPGA in LabView?
(3,048 Views)
Have you installed LabVIEW FPGA?
ALE Consultants
(3,042 Views)
A screenshot of your about window would help.  Menu help》About LabVIEW
"Should be" isn't "Is" -Jay
(3,015 Views)
I guess device drivers are not installed, Please check whether device drivers are installed?
(2,990 Views)
Which driver should I install? NI has a list of drivers since I’m using the DE1 fpga Altera board on my project.
(2,980 Views)
LabVIEW FPGA supports only hardware from NI
ALE Consultants
(2,974 Views)
You need labview fpga module to work on Labview FPGA. You can download evaluation from here. https://www.ni.com/en/support/downloads/software-products/download.labview-fpga-module.html
Also try saving project on computer directory. Your attached image shows project is not yet saved
ATE and Labview Consultant
https://www.easybodge.com
(2,912 Views)
