can't open session.....don't know where is wrong
select a single laser channel:
there is no wavelength output.....I don't know where is wrong...it just doesn't work......maybe the session is not opened???? or the command format I wrote is wrong?
I don't thinkg I miss something....but I just don't know where is wrong........sad
(2,552 Views)
why those conversion dots. you are multiplying a U16 to a constant ( 100, which i guess I32 ) which is not giving you correct datatype. Try making that constant into U16.
(2,537 Views)
duplicate post, continued from here.
Cantata, please stick in one thread!
(2,533 Views)
Hello !
Simple question, are you sure that your communication port is close before you try to open it ?
(2,525 Views)
You dont need multiple VISA write, instead you need to combine all the data which you need to write at once and write.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,511 Views)
