05-20-2010 11:33 AM
I am trying to access the "Excel._Worksheet" reference but when I use the "unbundle by name" I get a broken wire. The green object is the NI_report.lvclass and the blue object is the NI_Excel.lvclass.
Not sure why I'm being prevented from getting the reference this way since I see this working as shown in NI_Excel.lvclass:Excel Rename Worksheet.
(I'm trying get the Worksheet reference so I can call the _Worksheet.Delete method. I don't believe the Report Generation toolkit includes a Worksheet Delete VI.)
(I'm using LabVIEW 8.6)
-Joel
Solved! Go to Solution.
05-20-2010 02:42 PM
That's the incapsulation feature provided by LabVIEW classes, it protects the private content of the class. You can only unbundle in VIs that are parts of the class.
There is a VI that returns the application and document ref:
Ton
05-20-2010 02:56 PM
TCPlomp wrote:That's the incapsulation feature provided by LabVIEW classes, it protects the private content of the class. You can only unbundle in VIs that are parts of the class.
Ton
Adding to Ton's reply...
THe VI Ton showed you was omitted from the first release of the modified toolkit. We screamed so they added that VI to let us be creative. If you can't find that VI in your install, you will have to upgrade the toolkit.
Ben
05-20-2010 03:00 PM - edited 05-20-2010 03:00 PM
To be a little more specific, you need to be running LabVIEW 8.6.1 with Report Generation Toolkit 1.1.4 to get this VI. Or, of course, LabVIEW 2009 with Report Generation Toolkit 2009.
05-20-2010 03:05 PM
Any technical reason why the toolkit 1.1.4 won't run on 8.6?
Ton
05-20-2010 03:38 PM
My mistake. According to the Report Generation Toolkit 1.1.4 readme, you can use it with LabVIEW 8.6.
05-20-2010 04:02 PM
09-29-2011 02:16 AM
Hi TCPLomp,
Thanks for the information!!
But does anyone have any idea how to get the class reference from the ActiveX reference. This is exactly opposite to what NI is offering.
I don't know how the NI engineers missed out this point when they can offer one way, so they could also offer it the other way too and that's what even I'm looking for. I've worked upon something like adding/inserting a new sheet in the workbook (NI library has it) but at the place that I choose (not at the end like NI Library does). Why can't these engineers think in advance or atleast gives us the option to modify the library for our use instead of just restricting like that. I just want to understand that. I feel MATLAB is flexible in this sense.
Thanks for your help!!
Manjeeth
09-30-2011 01:19 PM - edited 09-30-2011 01:20 PM
Manjeeth,
In terms of getting the class reference from the ActiveX reference, try using a property node.
Also, I have attached a screen shot of a program that will allow you to specify where to add a worksheet.
Katie
