02-16-2010 03:01 PM
I have a HP83620A signal generator and I would like to use the Labview GPIB driver hp836xxa. It seems the older version has been deleted from driver listing. New version is 1.1 which is only compatible with labview version 7 and 8. Could someone save as older version 5.1 - and send to me ? email mwtechmail@yahoo.com
Ken
02-17-2010 11:45 AM
Ken is referring to this driver http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9571659CE034080020E748... . I was able to open the driver in 7.0 and save to 6.1, then open in 6.1 and save to 6.0, then open in 6.0 and save to 5.0. I got a number of errors and warnings along the way but the final product is attached to this forum below.
If you were using this driver in the past do you still have a computer with this driver installed? If so, you could just copy from that computer. These "drivers" are more or less pre built VI's that you can move from one computer to another you should be able to find it in LabVIEWs instr directory.
