can not run cDAQ9188XT
after installing NI-daqmx 18.5, i am not able to run cdaq9188xt from labview. Run option is broken. when i tried to load DAQInit-sub.vi file, it showing that ''fail to upload nilvaiu.dll''. even if i am not finding cdaq9188xt driver in NI-MAX.
Can some one tell me what is the solution of this problem?
kaium khan
(2,202 Views)
Could you please tell me which version of LabVIEW and OS you are using?
Also, to understand better the orgin of the problem: could you please open Test Panels in MAX for this cDAQ and test, whether you can read/generate signals properly ?
CLA,CTD,CLED
(2,164 Views)
