can not overwrite JPEG
Hello everyone ,
I am trying to save XY graph to a JPEG file using Write JPEG file.VI .
if I do not change of the file name everytime I save , It will NOT overwrite the previous jpeg file .How do I get this to work ? I want the VI overwrite the privous files (if there is any with the same name).
(2,558 Views)
Please show what you have done. Please attach an image or a VI in 2011 version.
(2,531 Views)
Please attach your vi. Generally "Write Jpeg file.vi" will never prompt the user for overwrite action, It will automatically replace the file with same name. We can't provide you the solution unless you share the vi.
(2,530 Views)
As Vij@y said, by default the image write function will overwrite so you should not have any problems.
Could it be you are also using a file dialog function that is not configured right?
(2,505 Views)
