08-04-2009 09:34 AM
I have two boolean controls one does write operation and other does read operation. what i want is when i trigger a write operation after it is done it should go to read case without user hitting read button. Please send with a small example and my button type is having latch mechanical action. i am using labview 8.5.
Solved! Go to Solution.
08-04-2009 10:19 AM
Well...for me its not very clear what you want to do, so maybe you can post an example.
Christian
08-04-2009 10:28 AM
Hey srinivas
What you want your program to do can be done using a State Machine architecture that uses an event driven user interface.
I have written you a small program that you can use by replacing the one button dialogs with the code you want to use at each stage.
I hope this helps
08-04-2009 10:31 AM
Can you send me the attached program in labview 8.5 ver
08-04-2009 10:35 AM
Hi christian,
Right now i have a code which works for 2 event cases for write and read operation. I want to change the existing code in which after write event case is triggered by user control should automatically trigger the Read event case without user intervention.
08-04-2009 11:09 AM
08-04-2009 12:26 PM
