calcuating continutiy in a data arary
I wanted to calculate the continuity in data array. And I used the following logic
C=0;
J=0;
A=[1 2 3 4 10 11 12 15 16 19];
B()=0;
For(i=0,i<=size of A ,i++)
If [A(i+1)-A(i)==1]
C=C+1;
Else
B(J)=C;
J=J+1;
C=0
My output should be
3
2
1
0
I tried to build this in Labview but i am facing problem if the “else” part of logic.
Kindly help me,
thanks in advance
(3,380 Views)
Hi Rajesh,
                Can you please explain what actually you are trying to achieve without providing your text based code?
Thanks as kudos only:)
(3,375 Views)
Accepted by Rajeshkumarc
Hi Rajesh,
Please check the attached vi. I tried to build the logic you explained.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,373 Views)
Hi Rajesh,
Gaurav k
CLD Certified !!!!!
(3,371 Views)
@danil33 wrote:
Hi Rajesh,
It seems to me a kind of homework application 🙂
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(3,366 Views)
Hi Rajesh,
Use this vi to get all the continuities for your given data array.
Anand kumar SP
Senior Project Engineer
Soliton Technologies Pvt Ltd
(3,353 Views)
Thanks a lot for your support. . its working. .
(3,323 Views)
