cRIO9024 - cant switch to active mode
Power surge caused the network go offline and I cant seem to get it working back again.
This happened once couple of months ago and I switched off and removed all the modules from the chassis and put it back again to make it work.
The scan engine is stuck in config and I have to switch it to active.
 This is the error message I am getting.
Ash
(713 Views)
Make sure you are connected correctly with the cRIO.
Also check that the module is inserted appropriately, is it recognized by MAX?
Try the suggestion in the error message: recompile and download the module file.
Best,
Andy
(677 Views)
