cRIO startup directory was typed STARTUP and now will not boot. How do I recover from this error or how do I rename the directory when my proxy server is read only due no startup files?
I loaded files on the cRIO but used upper case letters for the startup directory.  Now I cannot access the RIO since it didn't boot. The proxy server comes up read-only so I can't reload the files or change the directory.  I tried the RS232 port but I can't get it to respond to commands even though I can see the processor boot.
(3,237 Views)
In the worst case scenario, you should be able to reformat the cRIO from MAX?
(blog)
(3,228 Views)
There is NO need to put your entire question into the subject line of your post.
cRIO will not boot is a suitable subject line
(3,223 Views)
