07-19-2011 01:15 PM
I am looking for assistance in modifying the project example for the cRIO Power Monitoring Kit to allow using 9215 analog input modules instead of the 9225/9227s. I have successfully revised the code by replacing the data rate node with a loop timer, and removed the start/stop node. The program executes, but throws a DMA error (5002). Lowering chanel count or data rate showed no improvement.
Any help would be greatly appreciated.
Bosko
07-20-2011 02:13 PM
Contacted NI Tech support @ 1400 on 7-20-2011.
07-20-2011 05:29 PM
Hi Bosko,
Thanks for letting us know that you contacted tech support. When you get an answer, could you post back here with the result so that anyone else experiencing the issue will be able to reference this thread?
