cRIO acting as EtherCAT master controlling TIM-EC torque mordule as slave
Hi.
I have the following hardware:
- cRIO 9047
- TIM-EC torque etherCAT module (link: https://www.hbm.com/en/5577/tim-pnec-profinet-and-ethercat-torque-interface-module/
- Torque flange from HBM.
How can the cRIO 9047 acts as EtherCAT master to read the torque measurements from the TIM-EC module which should act as etherCAT slave?
How can this be accomplished? Do I need additional hardware for this?
I have been through this turtorial: http://www.ni.com/product-documentation/10555/en/ for setting up etherCAT on NI programmable Automation Controllers,
(2,205 Views)
Hi mkstech,
Setting it up should be quite straight-forward. The cRIO's second network interface can act as an EtherCAT port. You mainly need to install the "NI-Industrial Communications for EtherCAT" driver onto the cRIO, set up the 2nd network interface as EtherCAT, and configure the cRIO EtherCAT master in NI MAX.
This guide should cover everything: Setting Up EtherCAT on NI Programmable Automation Controllers
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(2,160 Views)
