Has anyone seen the following in MAX before? I have two cRIOs right out of the box. I plugged them into a switch and then plugged the switch directly into my computer, so I am not going through the network. One cRIO shows up fine and I get all the network settings. The other shows up in MAX, but shows what's in the following screenshot so I cannot configure the IP. I have also tried plugging directly into the cRIO and removing the switch from the equation, to no avail. Has anyone seen and resolved this issue before?
Went home for the weekend, closed everything and shut down my computer, along with turning off the cRIO. Came in today, plugged straight into the cRIO and the network configuration tab came up fine. Not exactly sure what fixed it, but maybe it just needed a weekend?
