06-27-2018 12:57 PM
TCP Write.vi has an output bytes written. Is it writing the correct number of bytes? You could also do a wireshark capture to make sure everything is being written correctly. If it is, then the problem is your python code is not reading the correct amount of data.
-Jordan
06-27-2018 01:13 PM
So I added a base encoder and now I'm able to send about 6/10 of the images (within the JSON) to the Python server
06-27-2018 01:20 PM
Just checked and my bytes written output in LabVIEW is the same value as my data_len in Python
What's a wireshark capture?
06-27-2018 01:51 PM
Wireshark is an opensource tool that lets you monitor Ethernet traffic. You can install it for free from here. Basically you start a capture that will let you see all the TCP packets being sent over your network. So what did you change with the base encoder?
-Jordan
06-27-2018 02:24 PM
-Jordan
I thought the issue might be unpacking the serialized binary, but it doesn't appear to be the case
06-27-2018 03:29 PM
So I've tried running the program with Wireshark several times now. Every time I hit capture Wireshark crashes and now I am beginning to get an error in LabVIEW:
Ethernet
Follow TCP Stream
LabVIEW Error
06-27-2018 04:12 PM
I got it working! I had to add a delay in between the last write and close of the TCP connection
