cRIO 9035 profibus module not supported
Hello again,
recently I had to re install the PC host (harddisk died). Now the Profibus module is no longer there, how could that happen?
I am worried that if I try to find it through the profibus configurator, it will delee whatever is on there and it will no longer do anything/ At least the cRIO is still running, but off course I can not change / compile the software that goes onto the cRIO
(2,772 Views)
Hi Steffen,
That module most probably is not from NI, but from a 3rd party provider. Did you install the drivers for that specific module as supplied of that 3rd party?
(Do you have any type number or other specific information for that module?)
(2,746 Views)
Hi GerdW
its that one
https://www.ni.com/en-au/support/model.crio-pb-ms.html
from Kunbus ex Comsoft. Seems they no longer exist, now its part of VIPM. Drama is, we still have LV2015 and the Comsoft configurator II is no longer in the www.
I think / hope I installed all the drivers. FPGA, realtime, Ni-RIO, profibus VISA
Cheers,
Steffen
(2,739 Views)
Hi Steffen,
@Steffen01 wrote:
its that one
Then you better look for the drivers in the backup/archive of your company server.
I usually backup all relevant drivers on our server…
Btw. I found the "Comsoft configurator II" using Google search, but you better use a good virus scanner before executing the file!
(2,735 Views)
Hi GerdW,
no backup ;-( was on the harddisk that turned itself into a solid state drive. Lucky I kept anything else on a 2nd disk. Except the Kunbus stuff. I found a few drivers, but seems version does not match. cRIO is very particular about that. I am hoping of getting rid of that profibus device soon.
Cheers,
Steffen
(2,710 Views)
Accepted by topic author Steffen01
problem solved. In VIPM is a small dropdown, then I can select ver 3.0.0.1. Now its happy
(2,689 Views)
