07-26-2007 03:45 AM
The cRIO 9004 problems with cRIO 9104 chassis
I am using cRIO 9004 with CRIO 9104.
One strange event happened after many times running LabVIEw VI in RT target of cRIO 9004 without clear the flash memory.
And one day, after I pressed the reset button on the cRIO 9004, the LED of the STATUS on the cRIO 9004 flash 4 times contiously, I have read the manual (P.11) on http://www.ni.com/pdf/manuals/373561c.pdf and of course I have finished software rebooting many times, but I really don't know what mean by
cycling power between crashes and how can I deal with it. When I open the Measurement and Automation Explorer, it can detect the cRIO 9004, but when I open the LabVIEW project, right click the cRIO and click deploy and it replies: Failed to connect to RT engine.I have done software rebooting and pressing the reset button on the cRIO 9004 many times, but the problem is not solved. I worry that it is due to the run out of the memory, how can I clear the cRIO 9004 memory by using the Measurement and Automation Explorer or LabVIEW 8.2? If I choose to format disk in the Measurement and Automation Explorer, will I need to reinstalled the pre-installed LabVIEW 8.2 inside the cRIO 9004?
Thank you for your attention.
07-26-2007 04:25 PM
