cDAQ 9136 installation problem
Many thanks. It's working now. I just changed the converter mini display to VGA for different monitor and finally detected.
CheersSmiley Happy
Message 11 of 19
(1,313 Views)
Hi.
I want to bring cDAQ 9136 by connecting to battery to the field to measure signals. But I don't have 220v power to connect monitor in the field. Is there any other way to connect cDAQ to my laptop?
Message 12 of 19
(1,293 Views)
Hi, Asgar,
I'm pretty sure the cDAQ will run with a standard 12V car or 24V truck battery!
Why not? There are a lot of DC-AC converters for use in cars available…
You can connect your cDAQ to your computer using USB or LAN, as is written in the manual!
Message 13 of 19
(1,286 Views)
I have tried many times, it only works with quick start with using mini display to VGA to monitor, keyboard and mouse. USB or LAN doesn't work at all and NI max can not detect the cDAQ.
thanks
Message 14 of 19
(1,282 Views)
Hi Asgar,
Use a DC-AC converter to provide power supply for a monitor…
I guess you need to write some (LabVIEW) programs to use those ports…
Message 15 of 19
(1,279 Views)
USB or LAN connection doesn't work for NI MAX or LABVIEW. How to write a program while we don't know the system is detected or not! In the field I want to measure for 18 hrs signals. I don't have UPS or battery for 220v. This must be very easy to connect by USB to laptop and use laptop instead of bring monitor to the field with 220v power.
Message 16 of 19
(1,285 Views)
Hi Asgar,
So you want to measure for longer periods of time but you don't have an UPS/battery/whatever?
What was your reason to get that decision?
Message 17 of 19
(1,276 Views)
I have battery 12 / 24 V which is enough to support NI cDAQ 9136. I want to use two laptops to collect data in the field which is easy.
Message 18 of 19
(1,274 Views)
Hi Asgar,
you have laptops which run continuously for 18h or more? Without an external battery/UPS?
You want to measure reliable in the field?
We already concluded you are using a cDAQ with in-built WinOS. You need to run your program/VI directly on this cDAQ and you need to use an external monitor with this cDAQ.
The other option is to write a program which runs on your cDAQ at startup and does all the communication over LAN (like network shared variables, network streams). Then you can connect with your laptop and receive the data using a second VI!
Message 19 of 19
(1,267 Views)
