boolean--void data typle error in migrating lidar guide robot from sb-rio to myrio
hi all
new to labview, doing my NI arc 2014 project, trying to migrate "lidar guide robot" example to myrio.
this is the best example i could find.
after compilation the fpga main file sucessfuly,
an error says can't pass boolean to void.
(3,234 Views)
I have seen this occur when the user has deleted the front panel item on the FPGA VI that corresponds with the Read/Write node on the Host VI. Do you know if this has been done?
Cameron T
Applications Engineer
(3,197 Views)
thanks your reply,
does it mean something missing in FPGA target file or host file?
not sure if you know any lidar example on myrio?
my lidar can be regonised as usb raw, but  in this vi only the ASRL INSTR resouce is accepted.
(3,185 Views)
Hello Jeff,
As far as what may be missing, it seems to be a simple stop button control on your FPGA Target VI.
As far as Lidar examples go, have you seen this resource?
https://decibel.ni.com/content/docs/DOC-35698
Cameron T
(3,165 Views)
