boolean signal counter
Hi
I found similar program about that i want but I failed to insert it into my VI, than...... I need a counter that indicate me how many times the boolean Led switch-on .
My VI is attached
Thanks all
Message 1 of 12
(3,214 Views)
Highlighted
comming soon
"Should be" isn't "Is" -Jay
Message 2 of 12
(3,205 Views)
Highlighted
I modified your code by:
  1. Added a shift register to maintain the current Count of "Siganl"=True
  2. Added a boolean case structure to increment the value in the shift register only when "Siganl"=True
  3. Added a numeric indicator to display the updated shift registers value.
  4. Cosmetic changes to improve apperances - I assume you stripped outsome additional functions however you may want to review the style guide here
Message 3 of 12
(3,198 Views)
Highlighted
Jeff, your code is not correct, because it generates multiple counts for each square wave. I think the OP only wants to count low-high transitions.
You need two feedback nodes (or shift regsiters), one for the boolean state and one for the counter.
Here's a quick modification, there are many ways to do all that.
Message Edited by altenbach on 01-23-2010 11:59 AM
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 4 of 12
(3,179 Views)
Highlighted
Your right!
I was counting iterations where Siganl was true.
I mis-interperated the post If the OP only wants to count transitions
Message 5 of 12
(3,169 Views)
Highlighted
Accepted by topic author Teo_CF
Jeff Bohrer wrote:
Your right!
this works pretty well (reverse the inputs to Implies and init the sr T to count negative transitions)
Message 6 of 12
(3,163 Views)
Highlighted
psstimplies2.pngsame thing but fewer clicks Smiley Wink
Message 7 of 12
(3,162 Views)
Highlighted
implies3.pngHmmmm Snippet cut off the invertSmiley Mad
Message 8 of 12
(3,154 Views)
Highlighted
I used the compound node instead of implies because I also needed to invert the output in this specific implementation. 🙂
(Of course if you use a case structure, you have a choice of what you do in the false or true case) 😉
Message 9 of 12
(3,151 Views)
Highlighted
Thank you very much for helping me guys!!
See you next times!!
Message 10 of 12
(3,114 Views)
