06-14-2019 06:56 AM
06-14-2019 06:58 AM
06-14-2019 07:38 AM
Thank you for responding quickly. It does have a data type (cluster) so not sure why it is showing. I guess by your response isn't an issue really because the arrays will be initialized during runtime. Thanks again
06-14-2019 07:43 AM - edited 06-14-2019 07:45 AM
Hi Trinity,
Because that cluster is empty? So still no datatype defined!
(Btw. do you know the difference between showing an image of (a part) the block diagram of a VI and attaching the whole VI? [Yes, sarcasm.])
How do you do that when the VI isn't executable???
06-17-2019 03:12 AM
In other words, LabVIEW doesn't allow arrays or clusters that don't have anything in it. Put something in the cluster, or replace the cluster with something else, and the wire will get solid.
Note that to unbundle a cluster by name, you need to give the cluster elements a label.
06-17-2019 04:21 AM
Your program looks like it might have a problem locating a typedef you were using for your code.
06-17-2019 05:35 AM
I did find the culprit. I had an array in my cluster that was suppose to be a string array but was an array of clusters instead. Thanks for everyone's help.
