My data is in the form of a string. It contains 0, 1, and X (don't cares). I have the data separated into individual spreadsheets and also in a 2D array. I am trying to create a table or some sort of listing for displaying the data. I want to add the data to a table containing a vertical and horizontal scroll bar with the ability to add horizontal cursors to mark trigger locations. Any advice on how to do this is greatly appreciated. Thank you
This might not be the best, or most efficient way to solve this problem, but this vi might get you going in the right direction. This takes 3 sets of data from memory (0's, 1's, 3's)... notice that instead of 'x' I used 3's because I didn't want to combine strings and integers in an array. But given the coordinates that these files contain, they will display the corresponding values on an array. One issue is that the array size must be defined before usage. I have it at 10x10. Enjoy.
My first instinct is to say you need a table control / indicator. But that does not really support the sort of highlighting I think you are looking for. I assume you want to highlight several arbitrarily located elements. And do it all programatically. I do not know a way of selecting muliple sets in a table and cannot figure out how to change the color of individual cells. How many elements are we talking here? How many "triggers" do you expect?
