best approach to implement Abort
Highlighted
Yes. If you need to maintain one power level and impedance setting for several minutes for example but want to be able to stop within 100 ms, then set up the test state with a timer. After each 100 ms interval you check the timer and check the Stop button. If either condition is met, then you go the the shutdown states, else you repeat the test state for another 100 ms.  You can use the Elapsed Time Express VI or a simple count carried on a shift register.
Lynn
Message 11 of 11
(114 Views)
