[begginer] start button executing sub vi only once
Hi, I'm very confused by, what it looks, very simple task.
I have a piece of code and I need to plug it to "start" button which will execute it once when button is pressed, execute once again if I press the button again and so on.
I tried with "while" loop and true/false button connected to it but, as you know, code inside the loop executes itself continously as long it's true which is incorrect, it doesn't stop when it should.
I woul'd like it like that: Press start->code in block executes once and thats it, no more unsless I press the button again..
Please advice.
ps: I attached piece of vi I need to connect with button. It actually works as inteded but I fail to make it executable with button.
Message 1 of 8
(8,775 Views)
You should surround your code with an event case structure in a loop, with the case being value change of your front panel control.
Message 2 of 8
(8,755 Views)
Accepted by JohnnyB.
An event loop is the way to go but since you're a beginner; this is the basic, simple way:
You need to right-click the button and change the mechanical action to latch when pressed (or released) to run just once.  If you set it to switch it will toggle.
Message 3 of 8
(8,748 Views)
Very simple.  See the attached code. I've added a loop, case structure, run button, and stop button.
Edit:  My code is exactly what Niquist published.  Remarkable.
- tbob
Inventor of the WORM Global
Message 4 of 8
(8,746 Views)
Great minds think alike, tbob!  Smiley Very Happy
Message 5 of 8
(8,734 Views)
Message 6 of 8
(8,700 Views)
Please, Can you post this VI in LabVIEW 2009??
Message 7 of 8
(8,262 Views)
Here you go, 2009 version. note that one file is missing.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 8 of 8
(8,260 Views)
