12-04-2020 12:57 AM
hey,
I have implemented the high-pass butterworth filter. The o/p of the signal is correct. when I changed it to band-pass filter. The o/p just disappears.
The filter type is changed from high-pass to band-pass by changing 1to 0 in the filter-type of Butterworth Filter.vi
12-04-2020 04:18 PM
At least in the version of Butterworth Filter.vi that I found, filtertype for highpass is 1 and bandpass is 2
12-05-2020 12:34 AM
yes sir, for type 1 i.e. highpass, the output is the processed signal. but when type 2 i.e. bandpass id applied, the output is not visible on the waveform graph
12-05-2020 12:50 AM
It would be much easier to tell what is going on in your VI if you had actually attached your VI to the post. Include your data as a constant in the block diagram, or as a control where the values are saved as default before saving and attaching.
